Results
First things first – I just hope your mouse wheel works! We've also got around to throwing in some results for the Intel stock cooler – you'll find them at the
very bottom of the page.
I had my reservations about the Thermalright, but just... WOW! We had strapped the 1,400RPM Noctua fan to it not really expecting much, but it would be my ideal fan of choice since it's
actually silent, not just "silent" like so many packaging claims. It's the second best performing cooler we've seen to date and
the only one that can deliver such excellent cooling performance without your PC sounding like a jet engine.
You have to drop down the table all the way to the Zerotherm BTF90 or Thermaltake coolers on mid-low fan speed before you reach an equally tolerable noise level – the Thermalright Ultra 120 eXtreme quite simply obliterates this record.
It's almost a shame we've pitted the Zerotherm up against it because it's an excellent CPU cooler in and of itself. At high fan speed it may even outperform the Thermalright on the graph, but if you were to use a 2,300RPM fan on the Thermalright it would perform even better still. That said, we can't recommend using either of these two heatsinks with a 2,300RPM fan though because it’s just far too loud.
The low fan mode drops the Zerotherm in around the Thermaltake MaxOrb / Arctic Cooling Freezer 7 Pro range for an appreciable noise, which is very good at 1,000RPM, but to my ears the fan is tolerable all the way up to 1,700RPM which should put it around the Zerotherm BTF90 performance and also touching the “high fan” performance we’ve seen from a lot of coolers.
        Zerotherm Nirvana NV120 (high fan)
        Thermalright Ultra 120 eXtreme (low fan - Noctua)
        Tuniq Tower 120 (high fan)
        Thermaltake MaxOrb (high fan)
        Cooler Master Hyper 212 (full fan)
        OCZ Vendetta (full fan)
        Thermaltake V1 (high fan)
        Zerotherm BTF90
        Scythe Infinity
        Asus Arctic Square
        Thermaltake MaxOrb (low fan)
        Zerotherm Nirvana NV120 (low fan)
        Gigabyte 3D Rocket II (high fan)
        Noctua NH-U12F
        Thermaltake V1 (low fan)
        Zalman CNPS9700 (high fan)
        Scythe Kama Cross
        Tuniq Tower 120 (low fan)
        Asus Silent Square Pro
        Cooler Master Hyper TX2
        Zerotherm CF900
        Gigabyte 3D Rocket II (low fan)
        Intel Stock Heatsink
          20
          30
          40
          50
          60
          70
          80
    Temperature (°C)
Delta T(CPU)
CPU Temp
Ambient Temp
